Help with customization
accacc
Post by accacc »
Cheers guys,
Been trying to find out the specific name of the items in the pic attached so I could customize them. I know they are QPushButton (in QWidget) but leaving it at that will affect all other buttons in the pic.
Any one has any ideas?
Thanks in advance.
Screenshot 2023-11-21 at 13-41-35 qBittorrent 4.5 - Download for PC Free.png
Screenshot 2023-11-21 at 13-41-35 qBittorrent 4.5 - Download for PC Free.png (425.46 KiB) Viewed 1030 times
Re: Help with customization
         <item>
          <widget class="QPushButton" name="selectAllButton">
           <property name="text">
            <string>Select All</string>
           </property>
          </widget>
         </item>
         <item>
          <widget class="QPushButton" name="selectNoneButton">
            <string>Select None</string>
           </property>
          </widget>
         </item>
There you go. Propertieswidget.ui
accacc
Post by accacc »
Thanks mate, you're very helpful.
How to modify this code to go in a stylesheet (qss)?
(actually I'm thinking of removing/modifying them from qbittorrent ui)
Not possible?
Thanks again!
What would you like to change about them?
accacc
Post by accacc »
Hey man sorry I don't get notifications about replies, don't know why used to work.
Anyway, here's what I want to do, remove this whole red rectangle area marked in the pic below.
Tried all approaches I know but to no avail.
I use qss stylesheet bc I just find it easier than re-compiling with every change.
So, if you have any pointers I'll be very thankful.
Thanks and sorry again!
Screenshot 2023-11-24 at 11-46-51 qBittorrent 4.5 - Download for PC Free.png
Screenshot 2023-11-24 at 11-46-51 qBittorrent 4.5 - Download for PC Free.png (419.67 KiB) Viewed 955 times
