backing up qbittorrent while it's running ?
Arnavisca
Post by Arnavisca »
(google translate helps me).
I always close the qbittorrent before backing up. Is this necessary? Can I make backups while qbittorrent is running?
Re: backing up qbittorrent while it's running ?
Could you clarify what do you mean by "backing up"?
You can use ChatGPT and DeepL too, they do a better job at translation.
Arnavisca
Post by Arnavisca »
I mean i copy these folders :
c:\Users\xxx\AppData\Local\qBittorrent
c:\Users\xxx\AppData\Roaming\qBittorrent
Arnavisca wrote: Sun Dec 03, 2023 9:11 am I mean i copy these folders :
Ah I understand.
Yes, please shut qBittorrent down to make a full backup.
But, you usually don't need to make one.
You could also make a .bat file to ...
1) Do backup
2) Start qBittorrent
3) Put this .bat file into Task Scheduler at logon
Arnavisca
Post by Arnavisca »
Peter wrote: Sun Dec 03, 2023 12:30 pm
Ah I understand.
1) Do backup
thanks for the reply
