Download blocked on Raspberry pi os, need suggestions to check
lozbrown85
Post by lozbrown85 »
I've received my pi 5 and installed raspberry pi os bookworm, and of course my go to torrent client qbittorrent.
Torrents don't seem to be working, even the standard Ubuntu torrent. All the trackers say not working or timed out. No peers found.
Seems like some kind of firewall blocking
- Pi has internet, (browser works)
- ufw doesn't seem to be pre-installed with pios
What should I check?
Thanks in advance on any suggestions to check
Qbittorrent version 4.5.2-3+deb12u1
Re: Download blocked on Raspberry pi os, need suggestions to check
Simply open the port by hand on your router; assign an IP via static DHCP; set the same port on the rpi in qBittorrent... and let 'er rip!
lozbrown85
Unfortunately I tried this and it didn't work.
It's like it's not able to get it to the tracker to announce
Try switching your DNS to Quad9/Google DNS, etc.
alexnt
Post by alexnt »
lozbrown85 wrote: Sat Dec 30, 2023 12:18 pm I've received my pi 5 and installed raspberry pi os bookworm, and of course my go to torrent client qbittorrent.
Did you solve the issue?
If not, what happens if you close and then start the client again?
