Is this a bug or misconfiguration? My torrents not saving to completed folders properly creating duplicate downloads
molitar
Post by molitar »
First let's start off with my configuration and than I will explain.
Now what I end up with is the completed folder like this.
C:\Downloads\00. Torrents\Completed\00. Torrents\Temp
So where .torrent files are to be copied it's creating the download files themselves to so I end up with duplicates for the download files.
C:\Downloads\00. Torrents\Completed\<files 1>
C:\Downloads\00. Torrents\Completed\<torrent folder name>\<files1,files2,files3>
C:\Downloads\00. Torrents\Completed\00. Torrents\Temp\<files 1>
C:\Downloads\00. Torrents\Completed\00. Torrents\Temp\<torrent folder name>\<files1,files2,files3>
What the heck is going on if I disable copy .torrents to the folders I do not get this problem. Seems to be a major pathing but as only .torrent files should be copied to the temp folder and it definitely should not be under the completed folder.
