Problem with cross seeding
alexnt
Post by alexnt »
There are some cases I am not able to cross seed.
I'm talking about private trackers and identical torrents.
So I already have downloaded a torrent from tracker A and want to cross seed it to tracker B.
When I open the .torrent file I get the message "Torrent Name is already in the transfer list. Trackers cannot be merged because it is a private tracker".
Option to merge trackers to existing torrent in advanced settings is unchecked.
Why doesn't it create a new independent torrent which will contain only the new tracker?
Is there any way to solve this and cross seed?
bob2306
Re: Problem with cross seeding
Post by bob2306 »
Have you tried renaming the existing entry?
alexnt
Post by alexnt »
bob2306 wrote: Tue Jan 23, 2024 8:29 pm Have you tried renaming the existing entry?
Yes, but no luck.
NXZ
Post by NXZ »
2 torrents with identical hash can't be added to one qBittorrent instance. To seed the other torrent, you need to add it to a 2nd instance (Make sure the listening port number is not the same used by the 1st one).
