setting up default download location
kkpp
Post by kkpp »
I'm running qBittorrent through docker. It is the first time I'm using it.
here is the code
services:
qbittorrent:
image: lscr.io/linuxserver/qbittorrent:latest
container_name: qbittorrent
environment:
- PUID=1000
- PGID=1000
- TZ=Etc/UTC
- WEBUI_PORT=8080
- TORRENTING_PORT=6881
volumes:
- /path/to/appdata/config:/config
- /path/to/downloads:/downloads
ports:
- 8080:8080
- 6881:6881
- 6881:6881/udp
restart: unless-stopped
I want to set default download location to /home/test2/Downloads.
can some one help me with what changes I have to do in the code to make it happen?
gderf
Re: setting up default download location
Post by gderf »
volumes:
Please use a code box when pasting a yaml file as it properly preserves the formatting.
You need to change the second quoted line to this:
- /home/test2/Downloads:/downloads
Your first quoted line is also incorrect and must be fixed to agree with your use case. This as a non-usable example only path: /path/to/appdata/config
