Is there a way to change the torrenting port without restarting QBittorrent?
metricspace
Post by metricspace »
This is it, I basically have a script to enable portforwarding.
The function that does it, natpmpc, changes the port randomly so I have to get the new port, close Qbittorrent, and reopen with the new port using
qbittorrent --torrenting-port="$port" &
Is there a way to change the port on the current session of Qbittorrent, similar as if you changed it in preferences?
chruez007
Re: Is there a way to change the torrenting port without restarting QBittorrent?
Post by chruez007 »
Hi i do change the port as follows
curl -i -X POST -d "json={\"listen_port\": $port}" "http://localhost:8080/api/v2/app/setPreferences"
and ensure you have activated
"Bypass authentication for clients on localhost" so your user is permitted to update the port
