Torrents with tracker errors as errored
mongoose
Post by mongoose »
Torrents that has tracker errors such as "not working" should show up as errored torrents.
If that is impossible maybe it could be possible to sort out torrents with tracker errors in another way.
Right now you have to sort the tracker column and trackers with errors will show no tracker, I don't really thinks that a solution.
Re: Torrents with tracker errors as errored
I tried adding this functionality - but if you add the feature - it breaks the tracker tier change functionality.
Like now you can click a tracker and left-right you have arrows. Those would break.
So is is what it is.
bob2306
Post by bob2306 »
I wouldn't like to see this implemented as it would make it hard to spot serious problems.
In public torrents, trackers not working is really common and very unimportant. In private torrents it's usually a short lived problem that we can't do anything about.
bamboula
Post by bamboula »
would it be possbile to have those torrents reporting a tracker error to become another color, so we knwn instantaly there is a problem with them?
for example, one tracker i'm using has not allowed ver 5 yet so it made a couple days those torrents were not working without me noticing it. and i only notice it because i wanted to download something and it wouldn't.
(no errer were reported in the sidebar that i keep hidden anyway)
