Function built in categories
Arelius
Post by Arelius »
I'm assuming it should be possible to use categories to setup automatic moving of the files from downloads folder into say tv shows, movies and so on.
..maybe I'm just to old to understand, but by my logical thinking it should be set ones, the values for each category and the destination and that should do it, from there one marks one torrent and assign a category, then the torrent (it files and folders should move automatically)
Well in my case no such things happens.. can someone explain what I'm missing?
My compose settings regarding this:
volumes:
- /appdata/qbittorrent/config:/config
- /media:/media
Arelius
Re: Function built in categories
Post by Arelius »
Could it be that qbt dose not activate automatic management even though I have it on? Cause when I click on one or mark several and from right klick menu chose aromatic then this feature actually works.. if that is the case, how can you change so qbt dose this automatically?
kamikazepl
Post by kamikazepl »
