I know this is probably a bit of an odd one, but since I've changed and added some new drives to my PC, when I go to save a torrent (not the torrent file, that IS set) the resulting download location for the completed file(s) QBittorrent remembers like 10 different locations that I've used in the past to download the resulting files.
It just gets a bit confusing when I go to tell QBT where to put the downloaded files and I get the last 10 locations to choose from. Is there any way, perhaps in the registry, where I can edit that or even erase all the remembered locations for downloaded files, and then just start over so that QBT will then remember just the few I actually use now?
Really appreciate any help!
Thanks!
A bit of an odd one... Alter previously remembered save locations for torrent files...
- Newbie
- Newbie
Re: A bit of an odd one... Alter previously remembered save locations for torrent files...
Thanks Bro, I'll check it out!
