Add "Content layout" options to torrent options and set location
hallo
Post by hallo »
It's a common thing where, after downloading something, the folder name needs to be changed:
/folder/files -> /new folder name/files
To keep it seeded, location also needs to change, but then it will just re-download into that folder:
/new folder name/folder/files
to fix this currently you have to delete the torrent and re-add it, setting new location, with ticking the "content layout"/"Don't create subfolder" option.
bob2306
Re: Add "Content layout" options to torrent options and set location
Post by bob2306 »
I'm not sure I'm following you. Why can't you do that through "Set Location"?
