v4.6.4 creating " " folder in download directory
ravenmonk
Post by ravenmonk »
More than once now, qBittorrent has created a folder within my selected Downloads folder with NO NAME (just a space), but my computer is treating it like the Downloads folder and all the files are in there, also like some kind of mirror or duplicate.
-I cannot delete it, I cannot rename it, and cmd.exe actions do not take effect
What is the solution to prevent this, and how can I fix this folder?
Temp fix: Used 7Zip File Manager to browse to this folder, then renamed from there and finally deleted. Disgusting.
