Asustor NAS, how to setup qBittorrent and VPN
g68
Post by g68 »
Helo,
I have an Asustor NAS. I set up a ExpressVPN (from config file) and try to hide qBittorrent behind it. I googled , found out where to set it, but
I see only these options - eth0 and lo. I see no tun0. Am I missing something ? Thanks.
Re: Asustor NAS, how to setup qBittorrent and VPN
The separate interface only shows up if you connect to your VPN via a specific protocol.
For example, OpenVPN connection will result in a tun0 interface.
Check your VPN providers docs if you can use OpenVPN.
bob2306
Post by bob2306 »
If the config file was for OpenVPN, make sure you started the daemon.
