Bug - Network issue: Persistent Input/Output errors even after reconnecting
s1l3nce
Post by s1l3nce »
qBittorrent & operating system versions
qBittorrent: v4.6.5 (64-bit)
Operating system: Windows 11 Pro 23H2 x64
Qt: 6.4.3
Libtorrent: 2.0.11.0
Boost: 1.85.0
OpenSSL: 1.1.1w
zlib: 1.3.1
What is the problem?
This is my current setup: I store my downloads locally on a hard drive, and once they're completed, they get moved to my NAS automatically.
The issue I'm facing is that whenever there's a connection problem, or if I simulate one, I start getting continuous input/output (I/O) errors. These errors don't go away even after I fix the connection. They only stop if I close and reopen qBittorrent. Strangely enough, the client keeps uploading data, even though these errors won't stop showing.
Steps to reproduce
Open qBittorrent: Launch qBittorrent and start any data sharing activity (downloading or uploading).
Simulate a connection issue:
Disable your network adapter to cut off the internet connection.
Re-enable your network adapter to restore the internet connection.
Monitor for Errors: Check the qBittorrent log for input/output (I/O) errors. These errors usually start appearing within a minute. Sometimes even immediately after restoring the connection.
Once the I/O errors begin, they will continue to show up until you close and reopen qBittorrent.
Thanks for the help!
s1l3nce
Re: Bug - Network issue: Persistent Input/Output errors even after reconnecting
Post by s1l3nce »
Any ideas of what could be causing this issue?
s1l3nce
Post by s1l3nce »
Btw, this was completely solved after an update, so it was most likely a version issue.
