Delete files but let empty directonies !
vincen
Post by vincen »
Hi
I'm using qBittorrent 4.5.2 on Linux Debian 12.
Everything works very well out of a little detail. When I decide to remove a torrent in the web GUI and select also to delete files it deletes all files regarding that torrent but not the directory itself which is quite annoying. Any ideas why ?
Thanks
Vincèn
Re: Delete files but let empty directonies !
Permission issues I'd say/think?
vincen
Post by vincen »
Would have been the easy solution but it's not as qBittorrent runs as same user as directory where torrents are stored so there should not be any problem of rights ;)
Anything in the log then? It's called "Execution Log" in qBittorrent.
vincen
Post by vincen »
> qBittorrent.
I'll have to investigate as it doesn't log in the syslog and I struggle to find qBittorrent settings life itself also :( Used the Swizzin system to install the seedbox but it lacks quite some documentation on how it setups everything :(
Why not just run qbittorrent-nox-static?
vincen
Post by vincen »
Peter wrote: Tue Jul 30, 2024 6:03 pm Why not just run qbittorrent-nox-static?
what's the difference ? with qbittorrent-static ?
ticedoff8
Post by ticedoff8 »
In my Windows system, that's a symptom of a rogue file being created in the directory before the torrent finished downloading (or deleted) or the folder is still open in another app (like File Explorer or a CMD window) and locked.
The torrent content may get moved or deleted, but the temp torrent folder gets left behind because it's locked or there is a rogue file left.
If you are using a NAS for the /download directory, you may want to check to see if the NAS export has oplock enabled for the export or if there is another application (like a Windows PC) that may have the folders open.
Also look for .files. They will not show up with a simple 'ls' command. But do a 'ls -la' and there may see a .file.
Picasa was notorious for scanning new folders and leaving a .picasa file in each folder.
AnLuoRidge
Post by AnLuoRidge »
I have the same problem. The logs say
Removed torrent but failed to delete its content and/or partfile. Error: "Directory not empty"
Upon checking
- There's no hidden files before or after the deletion.
- I haven't added any additional files into the folder.
- All the files in the torrent is 100% downloaded.
- I never opened this folder in OS.
- I opt in.!qB as the extension name of incomplete files but by the time I deleted the torrent there're not .!qB files
qBittorrent version 4.6.2, running inside docker container on DSM 7.2
btw I found a similar discussion on GitHub.
UPDATE 2024-12-23
I finally found these’s a hidden @eaDir in the folder. It’s not visible in macOS (even tho I revealed all the hidden files) because DSM hides it from SMB/AFP connection.
UPDATE 2024-12-24
I found qbit_manage can delete these orphaned directories automatically.
orphaned:
  # Orphaned files are those in the root_dir download directory that are not referenced by any active torrents.
  # Will automatically remove all files and folders in orphaned data after x days. (Checks every script run)
  # If this variable is not defined it, the orphaned data will never be emptied.
  # WARNING: Setting this variable to 0 will delete all files immediately upon script run!
  empty_after_x_days: 60
  # File patterns that will not be considered orphaned files. Handy for generated files that aren't part of the torrent but belong with the torrent's files
  exclude_patterns:
    - "**/.DS_Store"
    - "**/Thumbs.db"
    - "**/@eaDir"
    - "/data/torrents/temp/**"
    - "**/*.!qB"
    - "**/*_unpackerred"
