HI im Looking to optimize my qbittorent settings for my connection
i have a average download speed of 864mbps and upload of 100mbps
im using windows 11, on a 8gb ram pc downloading to a firecuda hdd, any advice as to what to set my numbers to appreciated
intrested if there any advanced setting i should be looking at to thanks in advance
Help With Settings
Re: Help With Settings
Default settings can easily max out even 10gbps, it's not the settings.
In your case, you are limited by your storage (Firecuda HDD).
I'd recommend using 4TB or larger NVME SSD drives. You can get Firecuda SSDs that have high endurance. Be careful, some are not fast, just high endurance. You need both speed & endurance.
