If you search for a file which has the character '[' then the file won't show you unless you search without '['. The character ']' works fine.
Also the search for character '[' works fine in webUI.
Thanks for the best bit torrent software.
Content search is broken
Re: Content search is broken
Maybe it uses regex, so you have to escape?
Like : \[filename
If you right click a field, sometimes you can switch between filter modes.
Like : \[filename
- Newbie
I tried \[ .. it didn't work.
Could you elaborate 'If you right click a field' .. what field, where do I right click ?
- Newbie
Filter by changes affect search for 'torrents', the bug is in searching for 'torrent content search'.
if file name is '[abcd] efgh'
we can search for 'abcd', 'efgh', 'abcd]', '[abcd]', '[abcd] ' but not search for '[abcd', '[abcd] e'
if file name is 'xyz [abc] efg'
we can search for 'xyz [abc]', '[abc] efg' but not for 'xyz [abc] ' or ' [abc] efg'.
