Issue: Cannot Apply Rules to Feeds
dmac
Post by dmac »
Hello! I'm using qBittorrent within Docker on Unraid. Appears to be an issue where I cannot add feeds to my rules. Even after adding an RSS feed, the field still won't populate. I've tried re-installing, reconfiguring, not sure what else to do? Thoughts?
Version: qBittorrent v4.6.6 Web UI (64-bit)
Re: Issue: Cannot Apply Rules to Feeds
And you sure the feed is right? Like if you open the direct link, does it work?
