WebUI on Windows 10
sandstrw
WebUI on Windows 10
Post by sandstrw »
Been using qBittorrent for a long while suddenly am unable to use the webUI on my local account(for Sonarr login). Message is: "WebUI configuration failed: Unable to bind to IP: localhost, port: 8080. Reason: Unknown error". I've tried different ports under different IP address configurations. Also tried a full uninstall / reinstall of qBittorrent, with no change, except that it worked on one of the reinstalls for about 5 minutes before erroring out.
Any suggestions on handling this?
Re: WebUI on Windows 10
Either put this to bind to all:
Or if you only want one interface, put that IP there.
If you don't want anyone on your LAN to reach it, simply use Windows Firewall and block the port from outside.
sandstrw
Post by sandstrw »
was the original state when installed, and is where I had the issue to start with. It just suddenly started disallowing webui access.
Check if anything is using 8080 first: https://stackoverflow.com/questions/481 ... on-windows
For example:
- https://www.nirsoft.net/utils/cports.html
- https://learn.microsoft.com/en-us/sysin ... ds/tcpview
- netstat -aon | find "LISTENING" |find "8080"
- netstat -abno
You also have a bunch of sus apps running in the taskbar. Do you have anything else for ""security"" besides crapware bytes?
sandstrw
Post by sandstrw »
Checked and nothing using 8080, malwarebytes is running for VPN
deliciousscrews
Post by deliciousscrews »
After upgrading to qBittorrent 5.0, I encountered the same issue. Using ‘127.0.0.1’ instead of ‘localhost’ solved it.
sandstrw
Post by sandstrw »
Thanks, this solved the issue.
EliasGray
Post by EliasGray »
Thank you so much for the help, solved my issue also.
