qbittorrent 5.0 view by seed time
hello. I'm completely new here and I'm looking for help. Since version 4.5.5 the ability to display torrents by seeding time has disappeared. How can I restore this basic option for me in newer versions of qbittorrent? Is it possible? I would prefer to use newer versions but the view by seeding time is most important to me.
Re: qbittorrent 5.0 view by seed time
You can sort torrents by "Time Active" column. To display it you need to right click most top row of the table (where names of columns are written) and select "Time active". It also display seeding time in brackets there.
ok, that was it. thank you.
