How to disable dark mode QB 5 into Docker?
Auximen
Post by Auximen »
I have Synology NAS with Container Manager / Docker, where installed QB 5 from qbittorrentofficial/qbittorrent-nox. After update to 5.0.0 version i have only dark mode into WEB-IU. How i can return light mode?
Thanks
Uderzo
Re: How to disable dark mode QB 5 into Docker?
Post by Uderzo »
I'm wondering the same thing, does anyone have any ideas?
cyberweasel
Post by cyberweasel »
Following. having the same issue.
grumpus811
Post by grumpus811 »
Bump. Any ideas? Upgraded to 5.0.1 and the dark mode is unreadable. Funnily enough found a way to modify the conf file to go back to light mode in Windows but it does not work in Docker.
chickenhead
Post by chickenhead »
Changing the theme in firefox from dark or auto to light works for me on macos. under Language and Appearance -> Website appearance
Would be nice to force it one way or the other via an env variable in qbittorent-nox.
grumpus811
chickenhead wrote: Mon Nov 04, 2024 7:32 am Changing the theme in firefox from dark or auto to light works for me on macos. under Language and Appearance -> Website appearance
What version of qBit are you using? I don't see an option to change light/dark theme in my settings. Using hotio.dev imagine, qBit v 5.0.1. In fact, there's no section Language and Appearance at all. The closest option I have is Language under Behaviour tab.
Either way, I solved the awful dark theme by installing a custom Web UI skin named "nightwalker". It's also a dark skin but it's much nicer on the eyes. There are many other options out there so this was the easiest solution for me.
Uderzo
Post by Uderzo »
grumpus811 wrote: Mon Nov 04, 2024 4:39 pm
He's talking about Firefox not qbit.
chickenhead
yeah firefox. you can get an extention to "Toggle dark mode" via a button
MabelHoward
Post by MabelHoward »
How? Can you help 60 year old man?
Edit: My problem solved.
mono
Post by mono »
qBittorrent v5.0.2 WebUI (64-bit) finally released switcher :)
