Which version is suitable for Windows 10 build 14393
WesternGoldsmith
Post by WesternGoldsmith »
Hi all,
My OS is Windows 10 version 1607 build 14393 x64.
Which version of qBittorrent is suitable for this OS ?
Thanks in advance.
WesternGoldsmith
Re: Which version is suitable for Windows 10 build 14393
@ MikeTaku,
Thanks for the reply. While searching among old forum posts, I have found something interesting! One forum post says that you can make portable versions with some tweaks and it will work on any latest Windows versions.
WesternGoldsmith wrote: Fri Oct 11, 2024 2:38 pm @ MikeTaku,
Windows 10 is still 100% supported I think? Only Windows 7 support was dropped as far as I know.
WesternGoldsmith
@Peter,
No, the installer shows a message box which says we need a Windows 10 with build number greater than 19xxx. I tried with more than one qbittorrent binaries.
