the image im using is the hotio but the same thing happens with binhex, and even using glutun with linuxserver.io qbittorrent image, last thing i have to test is using libtorrent v1
On a fresh boot of qBittorrent, everything is fine, but after about 15 minutes, I notice that my speeds drop significantly, and some torrents even stall (Ubuntu Server, ZFS filesystem, 128GB RAM, 12700K, tested on a 1TB NVMe and an 8TB HDD).
I compared the same torrents on a similar type of drive on my Windows system, and it downloads perfectly fine with no drop in speeds (13900K, 64GB RAM, tested on a 1TB NVMe and 4TB HDD).
My VPN provider is Proton, and I run it through WireGuard. During testing, I connected to the same servers on my Windows system, and Windows performed significantly better.
Is there some setting I’m missing in qBittorrent that's causing these issues?
Second problem:
This is related specifically to the Ubuntu server. I download to my temp folder, which is either the 1TB NVMe or the 8TB HDD, and transfer to my main ZFS pool when finished. The moves appear to be slow. I can transfer a similarly sized file from my Windows computer via Samba to my main ZFS pool much faster. Is this because the move process is different when it's done by qBittorrent?
Qbittorrent degraded perfomance in docker
- Newbie
