ThomIDGAF wrote: Mon Oct 21, 2024 3:24 amLooks like the consensus on the forums is 5.0 is basically broken.
No, consensus is acute PEBKAC.
> dark theme
People wanted dark theme, it was added, it defaults to Qt theme. "I don't like it." Cool.
There are a dozen awesome looking third-party themes. "No. I want the old look back!"
Cool, now they have the old white theme that they despised so much for years.
\o/
(Seriously, if you want dark theme, check the custom themes out.)
> can't download
Port forward/firewall. Fix it and you are good.
> search plugins don't work part 1
People installed custom plugins that did not receive any updates and that broke things.
Remove them all and you can grab the latest plugin bundle via the program.
> search plugins don't work part 2
People have been running qB since Windows XP on the same PC and now they have Python installed from the stone age.
If they remove it and install a new one, the plugin installation will be fixed.
As our favorite zoomers would say, "skill issue".
