[SOLVED] torrents not being removed after 3 days
ssateneth
Post by ssateneth »
EDIT/SOLVED: I was looking at the wrong column, "Added On", sorry. I should have been referring to "Completed On" for when it would delete torrents. It is correctly working with the OR conditional.
_______________
In the settings -> bittorrent -> seeding limits section, I enabled "when ratio reaches" -> 20.00 AND I enabled "When total seeding time reaches" -> 4320 minutes (this is 3 days)
I was expecting it to removing torrent if torrents reach 20 seed ratio OR if it seeds longer than 4320 minutes. But it appears to be using the "AND" conditional.
Is there a way to get it to use the "OR" conditional? Thank you. I use RSS to auto download and auto start torrents and I got a 5 gbps fiber connection but limited hard drive space - i'm just trying to jump start the initial seed swarm and can't afford to have terabytes of hdd space locked up. Thanks for reading.
