qbittorrent
Underlord90
qbittorrent
Post by Underlord90 »
I chose a qbittorrent file with 24 seeders but i m downloading from just 1
Re: qbittorrent
If you're only downloading from one seeder even though there are 24 available, a few things might be causing that:
- Other Clients’ Upload Slots: Sometimes, the other seeders don’t have enough "upload slots" open, so they can’t connect to you even though they’re online.
- Port Forwarding: Port forwarding is important. If you don’t have the correct port open, it limits how many people can connect to you. You can check this in qBittorrent under your connection settings.
