Hi, thank you for being helpful on this Forum!
As you can see in the attachment (qBittorrent in french), I have 807 completed files, 279 are active, 532 are blocked. What that means? Should I throw away 532 files?
Also, what means the sign [F] before the status?
I download with Air VPN. Thank you for any answer.
So many transfers blocked
- Ecran Bittorrent2.jpg (137.46 KiB) Viewed 827 times
Re: So many transfers blocked
- [F] Means "Forced". That status bypasses queue and other rules such as ratio/seed time for example.
- It's not "blocked", I think they mis-translated it. Put it on English and check. Maybe they are in queue.
Thank you for your answer.
Yes, "Bloqué" is a translation of "Stalled" (in the sense of "Inactive"). I assume that if a file is stalled, nobody tries to download it at the moment.
But I am surprised that the number of Inactive files (534) is the same every day. Does that means that almost 2/3 of my 813 files should be deleted?
