No DHT discover
ferrvittorio
No DHT discover
Post by ferrvittorio »
all downloads are stalled. With no DHT discover, zero nodes. (Deluge and Transmission are working fine)
operating system:
v4.6.7 64-bit Linux 6.6.54-2-MANJARO #1 SMP PREEMPT_DYNAMIC Tue Oct 8 03:11:08 UTC 2024 x86_64 GNU/Linux
qbittorrent:
5.0.2
What could be the issue
Re: No DHT discover
Is your port forwarded properly and you are using the correct port inside the program?
ferrvittorio
Re: No DHT discover
Thanks
I solved setting "datamodel 1" (older protocol) in router UPNP settings
