ShowRSS feed not automatic downloading since mid december 2024
MagicMike
Post by MagicMike »
Good evening,
I am using automatic download for my RSS feed from showRSS.info. Previous to mid december 2024 everything worked smoothly. Alass up till today nog anymore. I looked for a reason in my RSS-feed. I cannot find (like previous) the place where I can insert the link to my custom feed address. What I do see is that the custom feed address link is a https instead of http. Maybe that gives the problem?
Do any of you have a suggestion?
Qbittorrent version 5.0.3
Windows 10 home 22H2
Thank you for your reply.
amundoe
Re: ShowRSS feed not automatic downloading since mid december 2024
Post by amundoe »
I'm just a newbie too, but reading through the posts i seen yours and thought maybe you will have to enable SSL, might be worth looking at :D .
ggurman
Post by ggurman »
Check out EpisodeFeed.com. It was designed as a replacement for ShowRSS. The creator is always working to make it better and is very responsive to questions. You can also checkout the r/EpisodeFeed subreddit.
