Anyone else get 50 reported seeds (example) on a torrent listing but can only find 1 and only 1/11 trackers are alive?
I can't even get passed downloading metadata now on many.
Nearly every tracker down?
Re: Nearly every tracker down?
This is normal for public trackers. They come and go. Thankfully, as long as there are peers and you have active port forward, you will be able to get some transfer done.
Still, you can always use ngosang's project and add all the trackers by hand - this is what most do: https://github.com/ngosang/trackerslist
