Suddenly I can't download anymore
Wimsomnia
Post by Wimsomnia »
As the title states, suddenly, doesn't work anymore, VPN or not.
Keeps stuck on Metadata downloading. No new software installed.
Has anyone suggestions how to fix this?
Thanks in advance for your answers.
Re: Suddenly I can't download anymore
Check if you have anything set in Settings -> Advanced -> bind interface.
Check your firewall, security software.
It's something you set, just can't recall.
Wimsomnia
Post by Wimsomnia »
Thanks for your answer.
I already put my sec software out for 10 mins but no result...
So it must be the firewall, no? Because I tried another client and it was the same problem.
In the firewall, I tried to change the app's permissions(you go to an "old" configuration screen), only public is checked, I tried also to check private, which worked but I can't confirm it anywhere...when I re-opened it, it was unchecked again....
Wimsomnia
Post by Wimsomnia »
Suddenly, it's now fixed.......as it appeared, it's now gone....thx again for your suggestion!!
Wimsomnia
Post by Wimsomnia »
Problem is back, I don't understand, haven't changed anything meanwhile...
