LOG:
3/7/2025 2:04 PM - Detected external IP. IP: "45.65.90.136"
3/7/2025 2:04 PM - IP geolocation database loaded. Type: DBIP-Country-Lite. Build time: Sat Mar 1 03:21:54 2025.
3/7/2025 2:04 PM - Successfully listening on IP. IP: "::1". Port: "UDP/18362"
3/7/2025 2:04 PM - Successfully listening on IP. IP: "::1". Port: "TCP/18362"
3/7/2025 2:04 PM - Successfully listening on IP. IP: "fe80:
3/7/2025 2:04 PM - Successfully listening on IP. IP: "127.0.0.1". Port: "UDP/18362"
3/7/2025 2:04 PM - Successfully listening on IP. IP: "127.0.0.1". Port: "TCP/18362"
3/7/2025 2:04 PM - Successfully listening on IP. IP: "10.169.117.40". Port: "UDP/18362"
3/7/2025 2:04 PM - Successfully listening on IP. IP: "10.169.117.40". Port: "TCP/18362"
3/7/2025 2:04 PM - UPnP/NAT-PMP support: ON
3/7/2025 2:04 PM - Encryption support: ON
3/7/2025 2:04 PM - Anonymous mode: OFF
3/7/2025 2:04 PM - Peer Exchange (PeX) support: ON
3/7/2025 2:04 PM - Local Peer Discovery support: ON
3/7/2025 2:04 PM - Distributed Hash Table (DHT) support: ON
3/7/2025 2:04 PM - HTTP User-Agent: "qBittorrent/5.0.4"
3/7/2025 2:04 PM - Peer ID: "-qB5040-"
3/7/2025 2:04 PM - Trying to listen on the following list of IP addresses: "0.0.0.0:18362,[::]:18362"
3/7/2025 2:04 PM - Using config directory: C:\Users\phili\AppData\Roaming\qBittorrent
3/7/2025 2:04 PM - qBittorrent v5.0.4 started. Process ID: 16404
