Connection statut : no direct connections (without touching anything)
dezf
Post by dezf »
Hello !
Less than a week ago I was able to download my files correctly. But since yesterday, with no change on my part on my PC or on the qBittorent application, I've been unable to download. I get the error message Connection status: no direct connections (img in attachments).
As I said earlier, I didn't change my configuration between Saturday and yesterday. I use a CyberGhost VPN. I wanted to check if the problem came from this one, so I removed my VPN and put my “Network Interface: Any interface” but I still have the problem. Even with my normal connection, without VPN I can't download. I tried to make changes, I spent 3 hours trying to modify to solve the problem, I found nothing.
Here's a video of my qBit settings : https://youtu.be/bzu3hhqn2gw
I'm beginning to despair. Thank you for taking the time to read me.
dezf
Re: Connection statut : no direct connections (without touching anything)
Post by dezf »
The trackers of my website was the problem. Good to know
