i am running qBittorrent on windows server with PIA vpn app with a split tunnel configuration. Now i want to disable PIA but when i do that qBittorrent stops connecting with the trackers and thus stops down/uploading, even when i select the right network interface (not wgapia0 anymore but the correct ethernet adapter) and also setup the correct port forwarding within the router. There are a lot of posts where people asking how to get QBT working WITH pia, but it seems there are none describing how to get QBT working again without PIA.
What can i do to make QBT working again without removing PIA completely, just disabling it?
