Cant install search engines from a file or url
Audiogasm
Post by Audiogasm »
qBittorrent v5.0.4 WebUI (64-bit)
All download links from the below site dont work. Either by coping and pasting the url or by adding in the file from a local drive location.
https://github.com/qbittorrent/search-p ... ch-plugins
This only just happened since upgrading to 5.0.4 a few minutes ago. This was not an issue on the older version i had a few minutes ago
gderf
Re: Cant install search engines from a file or url
Post by gderf »
What older version were you using that did work?
Is python installed on your system?
