I Tested Qbittorent Qt5 for a long time, then suddenly it caused issues, so I moved to qt6 and it fixed the issues, but then the same issues happened with qt6 so I went back to qt5 and now it's again fixed. I can't understand what is going on. For the testing I always compared transmission side by side and it gave me over 127mb download compared to qt6 5mb. now I installed qt5 and the downloads are fine.
Which setting can cause this to misbehave like that? randomly or sustainably
it sometimes related to OS Cache, I have it disabled, last time to fix the issue I need to have it Enabled, but it didn't do anything this very moment it happened again. there was windows update just yesterday but then why it didn't work with any of the cache options? I needed to go back Qt5 to fix it with disabled cache.
