I need help
I need help
Someone helps me, that fire comes out and tells me that there are no direct connections. How do I solve that problem?
- Someone helps me, that fire comes out and tells me that there are no direct connections. How do I solve that problem?
- c861588e80b20236de0b6f4d02608740.jpeg (409.13 KiB) Viewed 4993 times
Re: I need help
Check if you enable qBitorrent and the port it used in Firewall/Antivirus.
Confirm with your ISP if you get public or private IP, if you get public IP - you should try to do port forwarding as well.
