What is the release scheduel for qBittorrent-nox?
qbitton
Post by qbitton »
I've recently setup an home server, and started using the nox version. I see now that the current regular version is at 5.1.0 and the nox version is still 4.6.7. What is usually the release schedule for the nox version?
Re: What is the release scheduel for qBittorrent-nox?
It depends on your Linux distro. They update the packages, not the qBittorrent team.
If you want up-to-date software on Linux, you should look into rolling release distributions, such as openSUSE Tumbleweed, Manjaro Linux, Arch Linux, etc.
SneakySneaker
Post by SneakySneaker »
You might want to look into qbittorrent-nox-static; or alternatively just download a precompiled binary that project provides. You could script it to download the latest binary when there is a new one.
https://github.com/userdocs/qbittorrent-nox-static
