Export search results
corsario28
Post by corsario28 »
Hi, I would like to bring the idea of exporting the search results as html, that way will be easy to find things.
The reason is, every time I run the search for the same word I get different results.
Even filtering brings different results. For example, if I search for SUN and then filter for BRIGHT, I get results of bright inside whatever has SUN but if I run SUN BRIGHT I dont get the result of the filtering
Im using x86_64-qbittorrent-nox 5.1.0 libtorrent 2.0.11
