I'm using the latest qB 5.1.0 (LT20) from PPA on Ubuntu 25.04 on my RPi 5 4GB. The RPi has a good SSD connected - Crucial MX500 1TB (with DRAM) in a USB 3.0 enclosure. This works with a 300Mbit/s FTTH (DL 37.5MB/s). My RPi works 24/7 as a seedbox/NAS.
Now, when I download a big torrent, say 100GB, after a few seconds from the start of the download, I get "write cache overload" and the download virtually stops. What I can see in Ubuntu's System Monitor is that qB constantly writes about 100 to 350MB/s to the SSD every second (but doesn't download anything at the same time). So there's a VERY unusual disk activity by qB. The actual download only starts after 1 hour or so (100GB torrent). When the torrent finally finishes downloading, I can see in System Monitor, that Total Disk Writes increased by around 200GB, but I have only downloaded a 100GB torrent, so it looks like qB has written twice the amount of data.
I have pre-allocate files disabled. I tried every combination of Disk IO type and Disk IO read/write mode - it doesn't help. I also increased qB's working set to 1GB and Disk queue size to 256000 kB - it doesn't help. I also tried a bit older qB from the official Ubuntu repo - it behaves in the same way. I tried to reformat the SSD, first to NTFS, next to exFAT - neither helped.
The only thing that helps is when I exit qB and start it again (even without OS restart). Then, immediatally after launch, it downloads fine (37.5MB/s), but the next day the problem comes back with a new torrent I try to download.
Any help appreciated.
Here's the SSD benchmark from Disk Utility:
