Did a theme reset...
I set everyone's theme to Argentum2 and made it the default.
This should've happened like months ago, but somehow I managed to forget about it.
There will be some other works after Sunday (generic maintenance).
And you may notice some slowdown on the forums too. Working on that one. It's the server. But what exactly, beats me.
ironcross
Re: Did a theme reset...
Post by ironcross »
Nice, nice :)
100%
Post by 100% »
Much better now, thanks shiki! :)
ironcross
Post by ironcross »
Actually i use this theme from the beginning (when we switched to SMF) and i thought everyone used it :D
Same happened to me, it's something you overlook easily.
When I switched into Incognito to test functions I did see the problem, but I couldn't find the option in themes and never had the time to deal with it.
Yeah I know. Sorry.
Also: Just installed mod_pagespeed a few days ago. Hope you will (or already do) see some speed increase.
Maybe I'll try that Google server stuff if the server gets that loaded. But I doubt we would ever need that.
-  Memory usage: 26%
-  System load:  0.05
ironcross
Post by ironcross »
Good improvement.
100%
Post by 100% »
[quote="shiki"]
Just installed mod_pagespeed a few days ago. Hope you will (or already do) see some speed increase.[/quote]
The speed improvement is obvious. Good job, mate!
100%
Post by 100% »
Could someone please either fix the address or remove the "Sourceforge" part?
loki
Post by loki »
Yeah but the download page points to sourceforge for Windows, Mac, and source... so...? Technically it's not wrong.
fix'd
The server will be faster once again. (It turns out the server won't have to host a site which gets like 3k visits per day.)
I offered Postbox that I could host them a forum, but they didn't reply. They really need one though.
100%
Post by 100% »
[quote="shiki"]
fix'd[/quote]
Thanks! :)
Dayman
Post by Dayman »
code tag doesn't seem to work in lists, has to be replaced by quote tag to keep formatting.
  • Item
    test
[*]Item with code tag
[/list]
code
  • [/li]
  • Item
    test
  • Item with quote tag
    code
Dayman
Post by Dayman »
Looks like parsing error.
What i wrote: http://pastebin.com/26jMWVqk
What i get after i click 'Modify Message': http://pastebin.com/j2HWGPBM
loki
Post by loki »
I just did an edit and I clicked the "Modify message" button, it opens in-line like it used to but it's completely blank, my previous text gone, even the subject line (required) blank.
