problem with connection
siickboii
Post by siickboii »
I have fedora 17 os and been using qbittorrent for a few weeks. Worked great then started having problems. I can still search fine but when I try to download the files it never will and gives me a 1/0 error....Ive opened it in terminal and this is my output.[[[[[[[
(process:3386): GConf-WARNING **: Client failed to connect to the D-BUS daemon:
Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
QGtkStyle was unable to detect the current GTK+ theme.
Qt: Session management error: None of the authentication protocols specified are supported
Couldn't set environment variable...
Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.]]]]]]]
Any Ideas how to fix issue??
