CPU usage
sirisiri
CPU usage
Post by sirisiri »
How high should qBittorrent's CPU use be? On my XP it's constantly using about 32% CPU. Is that normal? Isn't that a bit high? :)
tekko
Re: CPU usage
Post by tekko »
hmm... what's your cpu?
usually slower the cpu, higher the usage...
Re: CPU usage
What Tekko said basically. :)
(It also depends on your antivirus, on the encryption of the connections and the speed you are transferring speed.)
sirisiri
Re: CPU usage
Post by sirisiri »
This is a 5 years old core2duo computer, it was cheap then so it must low end processor. Anyhow utorrent is taking only 10-15% CPU, but I guess a new computer would be a wise purchase anyway. Dear Santa :D My antivirus is Avast
Avelon
Re: CPU usage
Post by Avelon »
My PC is about the same age. It's an iMac 2008, Core 2 Duo @ 2,8 Ghz on Windows 7. It's usage goes from 0 to 5 percent... so it's pretty low. I recently started to use ZoneAlarm Antivirus + Firewall, because it got pretty good AV results. All connections use forced encryption. DHT is on, PEX and LPD. UPnp is turned off, because it doesn't seem to work. I use fixed disc caching (currently 64MB testing).
