Annoying windows bug, all 'torrents' nameless
peterlmad
Post by peterlmad »
I haven't noticed it until now, but all of my torrents have no names. I've been "labeling" to remedy this problem but I would like a solution if any of you have one. I'd much rather cope with qbittorrent than ubotnettorrent
note the search function does work
Re: Annoying windows bug, all 'torrents' nameless
@peterlmad
Can you post a screenshot which includes the list's headers (ie the name of each column)?
loki
Post by loki »
Thinking it's possible that you shrunk the Name column until you no longer see it? Or, right-click on any of the columns and make sure Name is enabled?
peterlmad
Post by peterlmad »
hi i was able to fix this by following your suggestion and right clicking any collumn and re-enabling names, thanks!!
