Special build: qbittorrent 3.0.9 with libtorrent 0.16.8
Since many people encounter weird problems with the official 3.0.9 windows build, I did another one which uses libtorrent 0.16.8 instead of 0.16.9. This build is intended for troubleshooting purposes by the people affected. It is a test to see if the culprit is the new version of libtorrent used.
Instructions:
Please state:
1. What you problem is with the official build
2. And if it shows up in this build too.
link-> http://dfiles.eu/files/bga5ij6h6
Instructions:
Please state:
Re: Special build: qbittorrent 3.0.9 with libtorrent 0.16.8
seen working good with libtorrent 0.16.8
official > no UTP, only BT connection -
Special > UPT & BT are OK
official > torrent don't start,or blocked
Special > no problemo
official > qbitorrent don't close on exit, need to close him with kill process
official > don't contact tracker
Special > no problemo, all trackers working
my config >> windows7 32bits french, connected via private VPN
Interesting. I just hope other people can confirm these, so I can make a credible bug report to the libtorrent author.
Strange.
I've not encountered any of the problems described above with the official v3.0.9 build under WinXP32.
At least, not yet.
At least, not yet.
[quote="Tomaso"]
Strange.
At least, not yet.
+1, im surprised after reading them. Still on 3.0.9 with 16.9 for 1 week now and im yet to find any problem.
Strange.
At least, not yet.
Same problem here, not contacting the tracker, stuck at stalling or checking. Special build seems to be ok. Win7x64
I had some of the problems just after installing 3.0.9 in Windows XP Home Edition.
official > torrent don't start,or blocked (or checking forever)
Special > Perfect
Special > Perfect
This appears to be some sort of trap. link goes to a filedeposit site that keeps asking user to click on pictures of various objects, then when you click "download file" link you just get more pictures to click on.
[quote="OleaSTeR"]
[quote="OleaSTeR"]
Regular download, wait 60... enter code (or prove you're human), download link. Yes?
Guys could you also test the new special build? Thanks.
Forum thread: http://qbforums.shiki.hu/index.php?topic=1865.0->
I experienced consistent stalls with the official build. This will happen with one or multiple downloads. I had no problem with previous versions. I have just installed the "special 3.0.9" version. I will report back with my experience. I am running:
OS Name: Microsoft Windows XP Professional
OS Version: 5.1.2600 Service Pack 3 Build 2600
I'm a big fan of qbittorent! Thanks for the great work!
[quote="mobeustrip"]
Make sure you're not using the one in this thread, but the one from the link above your post. (Special build: qbittorrent 3.0.9 with libtorrent 0.16.9+svn)
Thanks for the tip, tekko. I realized that the "0.16.9+svn" build was available just after my last post. I've already downloaded that version and now I'm waiting for a good stopping point with a current download to install this version. I'll report back.
Hi, I'm a rookie here!
Upgraded from 3.0.5 to 3.0.9 official on XP Pro 32-bit
It stalls after around 500 MB download
And does not exit properly, some times it takes minutes and then the process disappears, some times I had to kill it.
Swapped back to 3.0.5 for now, is there a subversion certified to avoid this problem?
Hi there.
Just use the builds on the forum.
Here is the most recent:
http://qbforums.shiki.hu/index.php?topic=1747.0
! SAVE your settings before upgrading.
(Sledge stated the development will speed up.)
