Revamped stalled issue in sledgehammer's most recent special build
CrypticIce
Post by CrypticIce »
I've got the same stalled issue that users were having before with some things that I haven't seen users comment about.
First off, the torrents were doing just fine and then suddenly crashed. I closed QBT and reopened it and I got I/O error messages popping up from the tray that kept on flickering. The download/stall status of the torrent kept on changing with about a 3 second interval between downloading and stalling with 4 torrents open. I tried to force close with task manager and it wouldn't (and still) won't close as well as the process being "memory stuck" at 100,792 K. I uninstalled and installed the normal 3.0.9 and the issue persisted. I further uninstalled and installed 3.0.8 and STILL it persisted. I finally just switched back to the special build hoping someone would give me an answer.
Windows 7 OS.
Re: Revamped stalled issue in sledgehammer's most recent special build
What does the I/O error say exactly? You can see it from the log View->Execution Log (you can hide the filename if you want)
Do you download to temp folder first? (Tools->Options...->Downloads->Keep incomplete torrents in:)
CrypticIce
Problem fixed. My bad. Somehow my computer created several instances of the program and they couldn't read the files they were trying to write to the disk. Odd. Could be a glitch in my computer or the program. Thanks anyways.
