.pdb file omission from qbittorent 3.0.9
I find the packing with .pdb file (63 MB file) with qbittorent 3.0.9 (windows) of no use , i deleted it , tried it works perfect no issues....
Re: .pdb file omission from qbittorent 3.0.9
Nope it isn't useless. This file is used when the program crashes to get useful names of the internal functions called and display them to you so you can provide them in a bug report. If you delete it all you will get is "???" for the function names.
See discussion on the matter here:https://github.com/qbittorrent/qBittorrent/pull/337
