[Solved] Qbittorrent through VPN
Locked
GannTrader
Post by GannTrader »
I have set a random port  in QBT and restarted QBT.
Im using UPnP.
If testing the port with http://www.canyouseeme.org/ i get SUCCESS.
If i then start my VPN(PPTP) and check the port i get ERROR.
What do i need to do to run QBT through my VPN?
Im on win7 and QBT306
Re: Qbittorrent through VPN
You will be always firewalled through VPNs. You can't become active that way.
More info on this if anyone finds this topic:
When you use a VPN, you use the VPN's ports. The VPN is closed however.
IF it would have open ports (even just for a few clients), they could trace you down.
(And if they would open ports, you could run any service through the VPN. That would be a disaster.)
So it's both a privacy and business decision.
Locked
