OK, I am having a major issue with getting a port successfully forwarded for qBittorrent.
Running qBittorrent v3.0.10 on Windows 7 x64 SP1.
UPnP/NAT-PMP: Port mapping failure log:Router: D-Link DIR-655
Firmware Version: 1.35NA
Hardware Version: A2
Even my router shows that UPnP is working fine:11/07/2013 00:21:57 - UPnP/NAT-PMP: Port mapping failure, message: could not map port using UPnP:
11/07/2013 00:21:57 - UPnP/NAT-PMP: Port mapping successful, message: successfully mapped port using UPnP. external port: 31362
11/07/2013 00:21:55 - 'magnet:?xt=urn:btih:IE2CRCBU424MO2DWB2QKJQYIIRG5IIP5' added to download list.
11/07/2013 00:21:55 - Options were saved successfully.
11/07/2013 00:21:55 - Embedded Tracker [OFF]
11/07/2013 00:21:55 - Encryption support [FORCED]
11/07/2013 00:21:55 - Local Peer Discovery support [ON]
11/07/2013 00:21:55 - PeX support [ON]
11/07/2013 00:21:55 - DHT support [ON], port: UDP/31362
11/07/2013 00:21:55 - Anonymous mode [OFF]
11/07/2013 00:21:55 - HTTP user agent is qBittorrent v3.0.10
11/07/2013 00:21:55 - UPnP / NAT-PMP support [ON]
11/07/2013 00:21:55 - qBittorrent is bound to port: TCP/31362
11/07/2013 00:21:55 - Listening on IP address FE80::2CBD:D16E:83A3:49F1%17 on network interface {B551646B-93C4-45AC-891A-B8084EEFCDDA}...
11/07/2013 00:21:55 - Peer ID: -qB30A0-
So it should be working, but's it is NOT. Port 31362 is still closed and torrents show up as "stalled" in qBittorrent.UPnP added entry 255.255.255.255 <-> myIP:31362 <-> 192.168.1.105:31362 TCP timeout:0 'qBittorrent v3.0.10 at 192.168.1.105:31362'
Seems qBitorrent is alone with this issue. All other software on my network that requires a port to be opened or that uses UPnP works just fine.
Does NOT appear to be any firewall blocking it either. After all, you can see the request from qBittorrrent makes it all the way to the router.
Note the messages in RED. So it says within less than a second that it was successful and then failed. Pretty lame!
So then I tried to manually forward a port (tried 5 random ports, and no the ports are NOT already is use), and that fails as well.
Again, only having this issue with qBittorrent.
Thanks for the help,
Will
