Windows 8 compatible?
tyosei
Post by tyosei »
How come Windows 8 isn't listed in the download page?
http://qbittorrent.sourceforge.net/download.php
Are there any bugs in Windows 8 that aren't in the listed Windows versions (2000 / XP / Vista / 7)?
How does qBittorrent compare to uTorrent 2.2.1 in terms of data integrity / hash checking / downloading the files properly?
Re: Windows 8 compatible?
It should be compatible. I don't have really tested on Windows 8 though. But MANY users have reported that it works great. So you can give it a try and tell us too. Then I'll update the webpage. Thank you.
Pyro
Post by Pyro »
Oh, think I should have searches a bit before making a new thread :( sorry ;(
I don't know about others, but qBittorrent is freezing a lot for me under windows 8. I have no idea how to find the logs if there are any. It's freezing when I start a torrent or when I check older torrents and sometimes just when I click on it. I have literally no idea what could be causing it, I'm running a nice stable windows 8, just upgraded, no malware, Kaspersky IS 2014.
I wish I could do some kind of analysis.
